JordanC98
Newbie
Message 1 of 4
Smart hub 2
Im wondering how much download speed the smart hub 2 has on 2.4ghz and 5ghz
3 REPLIES 3
Message 2 of 4
Re: Smart hub 2
BT Smart Hub has seven antennas—good for 3x3 MIMO at 2.4GHz (max throughput ~200Mbps) and 4x4 MIMO at 5GHz (max throughput ~1700Mbps).
https://www.ispreview.co.uk/index.php/2018/11/bt-launch-new-smart-hub-2-broadband-router-and-complet...
JordanC98
Newbie
Message 3 of 4
Re: Smart hub 2
Thanks alot! Were upgrading to around 120mbps which should start tonight
Message 4 of 4
Re: Smart hub 2
Remember that the speeds quoted are optimum in lab conditions. Your real world speeds are affected by environmental issues such as walls, foil insulation plaster boards, wireless interference etc etc.
