Im wondering how much download speed the smart hub 2 has on 2.4ghz and 5ghz
BT Smart Hub has seven antennas—good for 3x3 MIMO at 2.4GHz (max throughput ~200Mbps) and 4x4 MIMO at 5GHz (max throughput ~1700Mbps).
Thanks alot! Were upgrading to around 120mbps which should start tonight
Remember that the speeds quoted are optimum in lab conditions. Your real world speeds are affected by environmental issues such as walls, foil insulation plaster boards, wireless interference etc etc.
