Cliff
Message 1 of 7
Smart hub 2.
I received the smart hub 2 on the 27/10 ,everything connected & seems to be working ok.I've been into hub manager & i noticed smart setup button,i didn't click on it.What would have happened if i had clicked it or should i have clicked it.
6 REPLIES 6
imjolly
Message 2 of 7
Re: Smart hub 2.
the forum suggests turning off smart setup as it can cause problems connecting devices especially wireless but your choice
Cliff
Message 3 of 7
Re: Smart hub 2.
But what does it actually do.I.E. Does it set everything to a bunch of default settings.
imjolly
Message 4 of 7
Re: Smart hub 2.
when adding a new device it attempts to help you set it up but in most cases prevents the device connecting and many customers wonder why devices do not connect and the reason is normally smart setup
but your choice you can leave it active - if I get a new hub first thing I do is turn off smart setup
Cliff
Message 5 of 7
Re: Smart hub 2.
OK,Thanks for help.
Cliff
Message 6 of 7
Re: Smart hub 2.
I've been into hub manager & taken a look at that smart setup button,i see what you mean after reading about what it does.I've turned it off.
Thanks again
licquorice
Message 7 of 7
Re: Smart hub 2.
I really have no idea why BT persist with it, it causes far more problems than it solves.
