Message 1 of 29
Smart hub 6 latest firmware update please?
I have searched for the answer to the above, to no avail.
Plse, can someone tell me if Smart Hub 6 is still receiving Firmware Updates,and when the last one was??
Thanks in advance.
28 REPLIES 28
Message 2 of 29
Re: Smart hub 6 latest firmware update please?
ppp1:TR69 connectivity to (pbthdm.bt.mo) has failed
Smart hub 6 dropped by BT
Message 3 of 29
Message 4 of 29
Thanks Aug for responding to my post. At least somebody has the decency to respond!!
Message 5 of 29
as this is a customer help customer forum members will normally only respond if the can help
the last firmware I can find for HH6 is SG4B1000E020
Message 6 of 29
My BT Home Hub 6 A updated to firmware version SG4B1000E077 on 22/2/22. I think (but can't be sure) that this is the first update in two years.
Message 7 of 29
Still SG4B1000E020 here and two years old - says March 2020.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 8 of 29
Thx for reply.Mine is still same as owzat ie March 2020, but as yours has updated i guesss theres still hope for mine!
Message 9 of 29
My BT Home Hub 6 updated yesterday (4 Mar 2022) for the first time since I've had it.
Firmware was updated to SG4B1000E077
So it looks like they are still updating. Can't tell what the update did though.
Message 10 of 29
Hub 6 Firmware update
Hello,
My Hub 6 Manager says that ive had a Firmware Update on 1 March 2022.
Its so long ago that i had one and cannot remember if , in order to activate it, i need to do something with the Hub e.g restart it etc. or would it matter if i just left things as they are............ "don't fix what aint broken" springs to mind!!
Please could someone let me know if it is important to do something with the hub or should i just leave it be?
