ForumHSP
Newbie
Message 1 of 3
Smart hub not showing connected devices
Hi,
Cannot find the link to contact Mods on your profile !
I am having the same problem as Paddy - some of my connected devices are not showing on my BT Smart Hub. Can you please help me resolve this ?
HSP
2 REPLIES 2
ForumHSP
Newbie
Message 2 of 3
Re: Smart hub not showing connected devices
Hi JohnC2,
Any response please ?
Moderator
Moderator
Message 3 of 3
Hi @ForumHSP Sorry some of your devices are not showing as connected. Have you completed a Factory Reset of the Hub and let me know if the issue persists after this is completed.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
