phit03
Message 1 of 2
Smarthub 2 Port Forwarding
Just switched to BT and installed the Smarthub 2 and configured it for port forwarding for 7 devices on my home network.
It works fine for a varying period and then stops working.
I check everything on the Smarthub, Dynamic DNS and port forwarded devices and everything looks fine.
If I switch the Smarthub off and back on again everything starts working again.
I've read that this is possibly the Smarthub running out of memory that causes the problem.
Is this a known problem and if so, is there a fix.
My previous non-BT router worked flawlessly for 5 years with port forwarding to the same devices and I'm no novice when it comes to setting up and using port forwarding.
Can I just substitute my old router for the Smarthub2 or is there a password required to access the VDSL connection?
1 REPLY 1
licquorice
Message 2 of 2
Re: Smarthub 2 Port Forwarding
Unless your old router is locked to another ISP, you can use it.
The username and password for PPPoE are the generic bthomehub@btbroadband.com  and BT
