I typed in the address given to update software but no response. Address http://192.168.1.1./
Hi @4doric I have no idea what you are trying to do but the default Hub address is http://192.168.1.254/
The IP address you mention, is used by other BT devices but not the BT Home Hub. Normally you would use the address mybtdevice.home and that would take you to the device interface, provided you are actually connected to that device.
