Amanda-smith25
Message 1 of 2
Speaker phone
How to put a bt phone with two handsets on loud speaker? The green button doesn't work
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Speaker phone
Hi @Amanda-smith25 Sorry you cannot get the speaker phone to work on your handset.
What is the model and make of your phone?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
