Unknownppls
Message 1 of 5
Static IP problem
Is there anyway to change a static ip at all as i believe my one has been compromised so i need to change it
4 REPLIES 4
licquorice
Message 2 of 5
Re: Static IP problem
If you are on residential broadband you won't have a static IP address, it will be dynamic. If you want to change it, just disconnect your hub from line for about half an hour and you will get a different IP address when you re-connect.
Unknownppls
Message 3 of 5
I believe i have a static ip as i think its a bussiness broadband
licquorice
Message 4 of 5
Then you need to post on the business forum, this is the residential forum.
https://business.forums.bt.com/
imjolly
Message 5 of 5
If you have business broadband then you need to post here. https://business.forums.bt.com/
This is a residential forum
