Message 1 of 2
Technical log entries dictionary?
Has anyone found an explanation of the various codes used in the technical log of the SmartHub2?  Some are relatively straightforward to understand but others are more obscure. For example I have several pages of this entry following a drop in my FTTP line overnight.
01:57:07, 12 Dec.
PPP: Sending PADI
01:57:02, 12 Dec.
PPP: Sending PADI
01:56:57, 12 Dec.
PPP: Sending PADI
01:56:52, 12 Dec.
PPP: Sending PADI
01:56:47, 12 Dec.
PPP: Sending PADI
01:56:42, 12 Dec.
PPP: Sending PADI
01:56:37, 12 Dec.
PPP: Sending PADI
01:56:32, 12 Dec.
PPP: Sending PADI
01:56:27, 12 Dec.
PPP: Sending PADI
1 REPLY 1
Message 2 of 2
Re: Technical log entries dictionary?
That is your hub trying to establish a PPPoE session with the BRAS.
