Message 1 of 5
Time to upgrade router. Is there one that works with BT whole home WiFi (white disks)?
I have a BT fire connection, a BT OpenReach modem connected to a AUSU RT-N66U (which is no longer supported). The wifi is switched off on the RT-N66U and there are is  on white BT whole home white mesh wifi disk plugged into the router and two more in discs in the house.
It's time to upgrade the Asus router. Is there one that works with BT whole home WiFi (white disks)? Ie so I don't have to disable it's wifi, but can use it as a fourth wifi point? I suspect not, but it's worth asking.
4 REPLIES 4
Message 2 of 5
Re: Time to upgrade router. Is there one that works with BT whole home WiFi (white disks)?
The white discs work with any and all routers, it's only the black ones where you are restricted ( to the BT Smart Hub 2)
Please help the community to help you by including all relevant information, single word responses may be quick to type but they offer little value to this Community Forum and do not help its team of volunteer members to help you.
Message 3 of 5
I could be wrong, but I suspect the reason for turning off the wifi on the main router is because it wouldn't form part of the mesh network but I assume as long as you accept that you won't get seamless roaming between router and disk, it should be ok to use the router wifi as well.
Message 4 of 5
I don't want two separate wifi networks that clash and reduce my usable speed. Ideally I'd like one mesh network that uses the three white discs plus whatever I replace the router with. I suspect that won't be possible, but thought I would check.
Message 5 of 5
Not sure why they would clash if you use different channels. I can't imagine that any router you buy would be able to form a mesh with the disks.
