Kahn1
Message 1 of 7
Turn off mini hub light
How do you turn that annoying nonsense off on the minihub? flashes 247 when im not using it
6 REPLIES 6
Message 2 of 7
Re: Turn off mini hub light
Duct tape!
Message 3 of 7
Put a piece of insulating tape over it!
Kahn1
Message 4 of 7
wont that block the vents?
Message 5 of 7
Don't wrap it up in tape, just cut a piece big enough to cover the lights.
Kahn1
Message 6 of 7
the blue light shines through the vents
Message 7 of 7
Try hanging a piece of card in front of the adaptor that will shield you from the light, failing that buy another adaptor that doesn't have any lights or learn to live with it.
