Nicdart
Message 1 of 4
Two disc premium set up
So I bought the two discs and have tried to set up as the instructions have shown me and vids I have found on you tube so I connect the first disc to my hub what for it to connect tunes solid blue then disconnect the Ethernet cable it goes red and then according to the vids and the my bt app it should go blue again  but it doesn’t are we saying I have to leave the disc connected to the router ? What’s the point  of tjat ... ? It would be in the same position as the router which I why I bought the discs ! Help!!!
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: Two disc premium set up
@Nicdart
Welcome to this user forum.
If they are the white whole home discs, then one of them must always be connected to your router, and you would normally turn the wifi off on your router, to avoid interference.
The only ones that work independently, are the black discs, and they only work with the BT Smart hub 2.
Nicdart
Message 3 of 4
Thanks Linda what I thought do I need to forget the Wi-Fi network on the hub ?
Nicdart
Message 4 of 4
sorry typo kinda*
