Message 1 of 4
Unable to change password on sh2
I go in to advanced settings, wireless, try to change the password, click thru the 'accept' dialog where it says about insecure password blah blah, click okay thru the message about devices being disconnected, it shows saving then saved.
Password then doesnt work and going back into wireless, just displays the default pass still?
Why is it not saving the pass?
3 REPLIES 3
Message 2 of 4
Re: Unable to change password on sh2
Are you trying to use 'special characters', can't remember offhand which characters the hub doesn't like but there are some. Try just alphanumeric characters
Message 3 of 4
Ive tried with and without special charas, both did the same thing and neither worked.
Message 4 of 4
Try a factory reset of the hub. Press the recessed button at the rear with a pin for about 20 seconds until the lights flash.
