kingmustard
Message 1 of 6
Unable to opt out of BT Wi-fi on our Smart Hub
The status page of our BT Smart Hub (running firmware SG4B1000B540) shows 'BT Wi-fi status' as Active.
We wish to disable this.
I have gone to this page, logged in and clicked on 'Opt out of BT Wi-fi' toward the bottom.
Nothing changed. Nothing popped up when I clicked on the text and the router status page still shows that it's Active.
Not sure if it's related but the text links only to: javascript:invokeOptOut()
Any ideas?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Unable to opt out of BT Wi-fi on our Smart Hub
These intructions may be helpful.
Opt in or out of BT Wifi using MyBT
It can take up to 28 days for any change to take effect.
kingmustard
Message 3 of 6
28 days?
Goodness me.
A message when you click the link would be nice. Something to let you know that what you've clicked has actual made some kind of effect on the other side.
licquorice
Message 4 of 6
Its not just a question of turning off the signal on your hub, it is also having to disable your access to hotspots whilst out and about.
kingmustard
Message 5 of 6
I understand but a message when you click the button would be nice.
acreations204
Message 6 of 6
I'm having the same issue, As the world is in lockdown i have no use for Hotspots elsewhere nor do i own a phone that receives a wifi signal.
Every page i come across sends me to a page where the button is unprogrammed and the links  to help are dead.
How do i opt out? Every avenue to do this is either  unprogrammed, deflective or missing.
Regards
AC
