darlo
Message 1 of 8
Unknown mac address uploading from BT Vision boxUnknown mac address uploading from BT Vision box
A few weeks ago I noticed a strange mac address on my home network which doesn't have an IP address or name. After trying to block (wifi mac filtering and parental controls) with no luck I started to unplug devices. This tracked it down to the BT Vision Youview box (it is not the mac address of the box). The address uploads data only usually around 35mb/hr but it can peak at several hundred. I am concerned from a security position on what this is doing as I have not given permission for this and it seems to evade all attempts at blocking it.
I am using an Asus RT-AC68U router and it shows up within the traffic analyser.
Any thoughts out there on what this is and does anyone else have the same problem?
Tags (3)
7 REPLIES 7
Message 2 of 8
Re: Unknown mac address uploading from BT Vision boxUnknown mac address uploading from BT Vision box
Do you use Powerline adaptors to connect the BT Vision box.
darlo
Message 3 of 8
I do but mac address of the homeplug is different and is connecting 3 other devices (TV, PVR and BluRay) so still active when BT Vision is disconnected.
Message 4 of 8
darlo
Message 5 of 8
I’d previously looked it up it is an Alcatel device. Not sure how that relates to the bt vision box though.
darlo
Message 6 of 8
Does anyone have any thoughts on this. BT are saying it is a youview issue, youview are saying it is a BT issue. Neither wanting to take any responsibility for it (or just help). I have been trying to block the mac address without sucess (I can block the BT Box's mac address but not the unknown one). The only surefire way so far to stop this upload traffic is to unplug the network cable from the BT vision box.
darlo
Message 7 of 8
Sorted. With some help from Gavin at BT (thankyou very much) this is an issue with multicast traffic and the asus router. Once with Gavin help we had tracked this to multicast data a quick search found a small number of references to a long standing bug in the firmware where the multicast download traffic is reported by the router as upload traffic and reported as such.
Moderator
Moderator
Message 8 of 8
@darlo Thanks for keeping the thread updated with the outcome of the investigation.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
