pg100571
Message 1 of 4
Upgrade from BT Home Hub 3 to BT Smart Hub 2
Just received my new BT Smart Hub 2, But alas there is no ADSL Filter which means that what appeared to be a simple upgrade requires another connection.
Mt BT Home Hub 3 connects via the white Open reach modem and this new upgrade should bypass this modem
Can I buy any ADSL Filter or is there a specification that I need to adhere to
3 REPLIES 3
licquorice
Message 2 of 4
Re: Upgrade from BT Home Hub 3 to BT Smart Hub 2
The modem connects to your phone line with a filter. You no longer need the modem use the filter that you used with the modem.
Simply unplug the lead in the DSL socket of the modem and plug it into the DSL socket of the hub.
pg100571
Message 3 of 4
Thanks Mate. Connection completed.
pg100571
Message 4 of 4
Thanks Mate, Connection Completed
