Aileen52
Message 1 of 19
Using a WiFi complete spare disc to hard wire into tv rather than long cable to hub
Can I use spare bt WiFi complete disc to connect with short Ethernet cable rather than yards to the hub to tv
18 REPLIES 18
VeteranISPUser
Recognised Expert
Message 2 of 19
Re: Using a WiFi complete spare disc to hard wire into tv rather than long cable to hub
Hi @Aileen52
I’m not sure how you ended up with a spare Complete WiFi Disc as they are loaned and owned by BT and should be returned if not in use. However I can confirm that the Ethernet connection works perfectly. Whether it works with BT TV you will be able to tell us once you have tried it Smiley Happy
licquorice
Message 3 of 19
Doubtful, because it will be using wifi to connect tothe hub rather than Ethernet.
Aileen52
Message 4 of 19
Thanks yes it works😀
Aileen52
Message 5 of 19
Thanks , so far it works 😀
licquorice
Message 6 of 19
Interesting, didn't think the Multicast packets would work via wifi.
Keith_Beddoe
Message 7 of 19
@Aileen52 only mentions a TV, not a BT YouView box, so I assume its just for a Smart TV.
Aileen52
Message 8 of 19
Hi, I have put the disc beside my bt you view box and with short Ethernet cable connected them and it works. So great not having yards of cable going from tv room to hub. The disc was sent as we thought it was lost in post but then turned up . You can have up to three I was told when I rang!
Keith_Beddoe
Message 9 of 19
Is it working on all of the extra subscribed channels as well, BT Sport etc, as they are the ones delivered over multicast?
Aileen52
Message 10 of 19
Hi ! Yes bt sport  and the kids channels I have subscribed to . That was yesterday when I tried. ! I haven’t checked today .
