jaybeetoo
Message 11 of 168
Re: Very close to returning my 2nd BT Whole Home WiFi...
- Exactly which devices are having issues
One+ phone
- Which software version they are running
Android 8.0.0
- When you first noticed issues (exact date would be very useful),
December
- What you're doing at the time you notice an issue (streaming audio/video, browsing websites)
Trying to get on network
- Which disc you're connected to at the time (the main one next to the router or a Wi-Fi connected disc)
WiFi
- And finally, does the device show any error messages against the Wi-Fi or any connections
No - trying to get an IP address
jaybeetoo
Message 12 of 168
MacBook Pro
High Sierra
December
Skype for Business
WiFi
No errors
Problem went away when I connected to the disc plugged into the router
spiderlane
Message 13 of 168
This is odd, I'm adding it just in case it's any assistance to @Dan-O...
I took my MacBook Pro upstairs so it would connect to another disc to write the previous message. Returned back downstairs (and connection has gone back to the problematic disc) but the connection has been rock solid since then. I haven't lost a single packet in the last 2,000 pings which is almost unheard of.
Also to add, the camera which is currently disconnected from the network but still showing connected is in the app, has a signal strength of -74dBm now but the "Speed" is fluctuating between "unkown" and "1Mbps". Again, just mentioning it for completeness.
Mark
MangoMan2020
Message 14 of 168
 - 2x Google Home (disconnections)
 - 2x Samsung S6 Edge Phones (disconnections)
- reconection established by restarting WiFi or rebooting devices.
 - Google Homes (latest firmware) - 106111
 - Samsung S6 Edge (latest firmware) - ANDROID 7.0
 - 29th December, when I received my 2nd (working) BT Whole Home WiFi. I updated firmware on the discs upon installation. As such, I have not had BT Whole Home WiFi working in a usable state since purchase.
  - Google Homes simply connected to network, says not connected when asked something. Shortly later, they are connected or after a reboot.
 - Samsung S6 Edges completely random. Can be in the middle of something or idle in pocket (wifi conenction active).
 - This has happened on all discs.
 - The S6 Edge devices often show authentification error on the wifi.
The S6 Edge devices are the worst by far, absolutely unusable and horrendous connection. I must stress that these devices were perfect before the BT Whole Home WiFi and are perfect now that I have reverted to my old network. The problem does involve the BT Whole Home WiFi
Dan-O
BT Devices Expert
BT Devices Expert
Message 15 of 168
Thanks all for your responses - very helpful. I will keep you updated.
@MangoMan2020 Just on your S6 Edge devices - have you checked for firmware updates recently? Could you tell me which version of Samsung software you have? (About Device > Software Information). Specifically baseband version, build number and Android security patch level.
Also, on your other Wi-Fi setup - is it dual-band (2.4GHz and 5GHz) and if so, are the SSID/passwords identical?
MangoMan2020
Message 16 of 168
Hi Dan-0
Information as requested:
Samsung S6 Edge, both using latest firmare update from Samsung via phone menu;
S6 Edge 64gb Baseband version - G925FXXS5EQL1
s6 Edge 128gb Baseband version - G925FXXU5EQJ5
My other WiFi is dual band, yes. The SSID are different for 5ghz and 2.4ghz (my preference in the router settings), passwords are the same. I also have a netgear extender in that setup, with a different SSID, but again same password. All devices are fine on this, and work perfectly.
Thank you for the help.
jaybeetoo
Message 17 of 168
iPad
iOS 10.3.3
December
WiFi
No internet connection
After about 10 minutes it gets onto the wifi
pridout
Message 18 of 168
Google Home
Sys firmware 106111
cast firmware 1.29.106111
About a month ago
Streaming audio
WiFi connected disc
Google Home says 'something went wrong'
This behaviour seems to happen if the connection switches disc or fequency band. I don't undersand why it should switch since the Google Home I am having a problem with is in a fixed position in the same room as and not more than 8 feet from the nearest disc. But sometimes it randomly connects to one of the further discs and/or hops frequency band.
js25
Message 19 of 168
As I mentioned above, my problems occur with general web browsing on my MacBook, using either safari or chrome. I tried running a ping to my router as someone suggested, and noticed the problems usual occur if I tried to load a secure https website -I’m not sure if this is relevant...
Anyway,  as I’ve got the discs to behave with powerline, my MacBook now connects to a disc connected by ethernet over powerline adapters, and I don’t seem to be suffering form the dropping connection problems any more.
rgbrgb2001
Message 20 of 168
Google mins; lose connection
Latest as per december update
Minis just installed in week before last firmware update
Mini wont work as it says no wifi, requires reboot
Varies
As I said it lose the wifi signal (all my other gear such as laptops and phones work fine). WIFI meter shows plenty of signal
