Message 51 of 168
Re: Very close to returning my 2nd BT Whole Home WiFi...
Glad that this seems to be working for all - remember to boost my rating
@Dan-O  Is this steering necessary ? as the devices themselves seem to be able to switch discs as required
Also iPads and Macbooks have always had issues with wifi connectivity where as iPhones have seemed stable.
BT Devices Expert
BT Devices Expert
Message 52 of 168
@Steve59
Most modern devices are capable of moving between discs by themselves. Some devices are sticky and connect to a particular access point.
It depends on whether they support the 802.11v standard for band transition as this will enable devices to move seamlessly with no interruption.
Message 53 of 168
I've also applied the workaround to disable steering and mailed support
Message 54 of 168
Applied workaround seems to work as google home now not dropping out. Only downside it takes longer for my devices to switch between disks when moving around house. Hopefully BT will provide a software update soon.
Message 55 of 168
hi when i try to turn off steering I disable it and then hit save and I get cmd_syncwifisteer msg send error.
reboot does not cure
thanks
hash
Message 56 of 168
Try powering the disks off and back on. It worked for me.
Message 57 of 168
thanks already tried that no change
sometimes it takes the changes but it doesn't save the option other times it doesn't take the command and errors
thanks
Hash
Message 58 of 168
I've done the changes and yes, the Google home devices are remaining connected. However mobile devices are struggling to change between discs and it causes weak signal issues as the phones don't switch when they should.
Message 59 of 168
Looks like google may have a fix to the google home cast issue effecting wifi https://support.google.com/chromecast/answer/7634752 will try this and put steering back on the BT WIfi.
Message 60 of 168
Do you know the latest firmware number for the Home, Mini, Chromecast and Chromecast Audio?
