Steve59
Message 91 of 168
Re: Very close to returning my 2nd BT Whole Home WiFi...
@Dan-O
Please can you advise what has been addressed with this release due on 26th Feb, issues i have found
Steering did not work for Macbooks
iPhone app loses connection with discs, discs needing to be rebooted weekly, note my SONOS mesh or HUE mesh never needs to be rebooted
Web interface does not work properly
Steve
BT Devices Expert
BT Devices Expert
Message 92 of 168
Hi,
There is no official changelog however the main changes in the disc software are:
- Improvements to device connectivity (particularly the common devices on this thread - Google Home, Macbook Pro etc)
- App performance and stability improvements (including fix for the "no response" error on install)
- Refined daisy chaining (more adaptive and less dependent on boot up order)
- Blank web pages fix
- General improvements
To get the benefit of these you will need to update the disc firmware as well as the app. If you are having problems with the app you can update the firmware using http://mybtdevice.home after rebooting your discs.
Dan-O
shaunmpond
Message 93 of 168
Hi Dan, will we need to reset the steering when this has been applied?
BT Devices Expert
BT Devices Expert
Message 94 of 168
@shaunmpond
Yes - if you've applied the workaround you should go back to the same page and set All Steering to "Enabled".
shaunmpond
Message 95 of 168
thanks - thought it was worth checking!
Shaun
spazicus
Message 96 of 168
Dan-O, has the localhost constant dns query been fixed in the pending release?
https://community.bt.com/t5/BT-Devices/BT-Whole-Home-WiFi-Firmware-localhost-bug/td-p/1823997
BT Devices Expert
BT Devices Expert
Message 97 of 168
@spazicus Yes this is included in Monday's release.
Dan-O
Steve59
Message 98 of 168
@Dan-O
I hope this release on Monday will avoid me having to reboot 2 of my 4 discs, once rebooted they connect "Good" and "Excellent" so not sure why they drop off in the first place and the App loses connection
App Says I am not connected to the Network when clearly I am ! again rebooting discs sorts this but its painful
As mentioned above I do not have to reboot SONOS or HUE devices
Is this also addressed
jaybeetoo
Message 99 of 168
Steve59
Message 100 of 168
Apart from jaybeetoo has anyone else managed to get the update ?
