shaunmpond
Message 121 of 168
Re: Very close to returning my 2nd BT Whole Home WiFi...
they're old Foscams - 802.11b only. Interesting point about compatibiity mode, I've enabled it, and we'll see what happens. cheers 🙂
Dan-O
BT Devices Expert
BT Devices Expert
Message 122 of 168
@shaunmpond
That will certainly help you.
In order to be more efficient, WHW uses a minimum data rate of 6Mbps rather than 1Mbps - essentially meaning that less airtime is used for overheads and control traffic. This means 802.11b clients may struggle to connect properly as they will use 1Mbps.
One of the changes in compatibility mode is the minimum date rate is set down to 1Mbps (802.11b) so this should help you.
Thanks,
Dan-O
chrisell
Message 123 of 168
Hi - just to update you all ....
i ended up doing a factory reset - then updated each disc firmware individually , reconfigured and they are all back up now ...
No devices currently showing as puased - which was my biggest issue ( lets hope thats fixed)
regards
Chris
MangoMan2020
Message 124 of 168
I've finally been able to update after resetting the discs.
Can you confirm what the steering page should look like now?
I have 'All Steering' as enables.
AP Steering and Band Steering as disabled.
Legacy Steering as enabled.
Period and Thresh = 10.
Thank you.
Dan-O
BT Devices Expert
BT Devices Expert
Message 125 of 168
@MangoMan2020
You can set everything to "Enabled" now as there are changes to improve stability with steering in this release.
If you do still have problems, it'd be best to start with turning legacy steering off but I don't expect that'll happen anymore in this release.
Thanks,
Dan-O
chrisell
Message 126 of 168
Is theer any way to stop it checking for updates in the app ? - i've already turned off auto updates but i'd like to keep on this version as it seems stable for now ...
MrX911
Message 127 of 168
My system is aabout 2 months old and has been rock solid. It updated a few days ago to the latest firmware and now just contstanly needs rebooting everyday.
Purchased it from Currys, anyone know what my consumer rights are if I think its not fit for purpose. Its becoming an absolute nightmare.
Steve59
Message 128 of 168
@MrX911 Whats the reason for rebooting ? Devices dropping off ? Red Lights ?, do all discs show the updated firmware in disc details ?
Have you powered off from switch on all discs ?
MrX911
Message 129 of 168
All discs updated show latest firmware. Most of the time discs show blue line but connection is down, app can’t connect and the occasional red red light.
I have switched it off for 10 mins and seeing what that does.
Steve59
Message 130 of 168
What about trying the web interface rather than the app
