Message 111 of 168
Re: Very close to returning my 2nd BT Whole Home WiFi...
@Dan-O so far, so good, thanks again!
Message 112 of 168
Hi @Dan-O
I have now downloaded the new app, not really any UI enhancments
Canm you put on the wish list
The ability to delete/remove devices that no longer connect
The ability to restart an individual disc
Many Thanks
Steve59
BT Devices Expert
BT Devices Expert
Message 113 of 168
@Steve59
Thanks for the comments - this release was focused on responsiveness and steering rather than new features.
I will take note of your comments for future releases.
Thanks,
Dan-O
Message 114 of 168
@Dan-O- sorry, it's stgill failing - logs are showing
27.02.2018 12:55:02 IF[2.4G]:AP deauth STA(<mac address>),reason is 15
any ideas?
Message 115 of 168
No real expert shaunmpond, but I can see a reset coming
Message 116 of 168
it'll be a pain if so, having to reset the SSID/password for both the normal and guest networks, but not impossible. There seems to be periods of stability, so I'm not panicking yet 😉
Message 117 of 168
Did you reboot the router as well ?, also surely you just reset the SSID and passwords back on the WH not change them
BT Devices Expert
BT Devices Expert
Message 118 of 168
@shaunmpond
Reason 15 for a deauth is an error in the 4-way handshake when a device authenticates with the network - can you check the device has the correct password?
May also be worth "forgetting" WHW network from that device and reconnecting. Also make sure that device has the latest software?
Message 119 of 168
hopefully they all (4) should have the correct password - the app shows them all connected OK. The devices that seem (anecdotal data only, I've not had time to check properly yet) to be the old webcams, so I've tried disabling legacy steering only, just as a test.
BT Devices Expert
BT Devices Expert
Message 120 of 168
@shaunmpond
Do you know if the webcams are 802.11b or 802.11g only?
Have you tried turning on compatibility mode on the Wi-Fi configuration page to see if this helps?
Dan-O
