Message 1 of 2
WIFI Discs keep dropping signal and disconnecting with Home Hub
I hope you can help? I have 2 Wifi Discs that have worked seamlessly for many months but have suddenly started disconnecting. My iphone and other devices will connect and then drop. The lights on the discs change from flashing blue to red. The Hub Manager App shows that they connect and go blue but soon go red. Just what you don't need in lockdown. Any advice or help?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: WIFI Discs keep dropping signal and disconnecting with Home Hub
You don't say which discs but I'm guessing the black ones, if so logon to your hub, advanced settings, wireless & check Wireless Mode is 1.
Note that if it's not 1 because you needed to change it at some time then that issue may well resurface
