RectoryBob
Message 1 of 2
WIFI EXTENDER 600
Hi,
I have recently purchased a Dual-Band Wi-Fi Extender 600 and set it up as per the instructions, however although the lights show too close - too far as expected I never see the extender as a device to connect to from the iMac - Question is : Should I or is it transparent?
Thanks Bob
1 REPLY 1
RectoryBob
Message 2 of 2
Re: WIFI EXTENDER 600
Whoops - sorry I have found the answer., it is an extension not a new SSid
Tks
