Deryman
Message 1 of 1
WIfi calling QOS
I think that wifi calling from my iPhone is having problems when connected to a BT whole Home disc that is using wireless to backhaul via the master disk to the internet. It seems to work fine when connected directly to the master disk. Don't know if it is signal quality or latency etc.  Are there any hidden Whole Home settings that can be accessed to set QOS on ports needed for VOIP?
