Message 1 of 2
What URL to get a new Homehub2 - wifi is failing
Hi folks
is there a URL or phone number  I can ring to get a new homehub2
I see on line that there is a slate of Wi-Fi hardware failing on new units - I have had mine 3 months and Wi-Fi signal now is so weak that is only works in the room where the router is located - used to reach all the way to my back garden - and I have changed nothing since the system was set up the day we moved into the house - frustrated @support
Tags (1)
1 REPLY 1
Message 2 of 2
Re: What URL to get a new Homehub2 - wifi is failing
@ArubaDerek wrote:
Hi folks
I see on line that there is a slate of Wi-Fi hardware failing on new units - I have had mine 3 months and Wi-Fi signal now is so weak that is only works in the room where the router is located - used to reach all the way to my back garden - and I have changed nothing since the system was set up the day we moved into the house - frustrated.
Ring 0800 800 150.
