Message 1 of 6
What is this box outside my house for and can it be moved/removed?
We have a new wiring box from Openreach for our full fibre but there is a very old BT box outside, which contains some old wiring (some that have been cut). Can this be moved/removed?
I can't add a photo of the box, which is unfortunate!
Thanks.
5 REPLIES 5
Message 2 of 6
Re: What is this box outside my house for and can it be moved/removed?
 Why would this be?
Message 3 of 6
Are there any wires that have not been cut, not if so where do they go?
Message 4 of 6
Two wires come out of a tube going underground. One goes to next door and the other is an old one used for the old landline etc.
Message 5 of 6
I don't suppose your neighbour would be too impressed with you cutting the wires for his service.
Message 6 of 6
Difficult really for us to advise without seeing a photo.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
