Message 1 of 2
Whole Home Connection Problems
Really frustrating that despite numerous restarts none of my devices PC, Mac, iOS, Android will now connect to the system. When the system was first installed they did connect but now they won't. All disks showing constant blue lights and visible to devices. Passwords also re-entered. I have four disks and the master is connected to a BT Home Hub.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Whole Home Connection Problems
Hi @adrianyolanda Sorry you are experiencing a problem with your Whole Home wifi set up.
You should contact the product helpdesk for assistance with this issue.
By phone: 08081006116 open Mon to Fri 9.00am to 5.30pm and Sat 9.00am to 2.00pm or drop them an email: btconnectedhome@bt.com
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
