Message 1 of 1
Whole Home Connectivity
I have had the three discs in use for 6-7 months without any problem, but over the last week it has been very sketchy.
The wifi connections all drop, no devices on wifi can access the web, however the discs all show as online. The wired connections (connected to discs) still work though. Rebooting the router seems to be required to get everything back. Wifi on the router is off so I am confident the problem is the BT discs.
connections drop multiple times a day.
Firmware v1.0.2.13 build07, updated 20th Dec 2021.
