Message 1 of 2
Whole Home Disc Sets using as additional discs
Hi there
can anyone answer the following question.
if you have bought a set of two whole home discs then buy another set of two can these be added to get or do you have to buy the additional single disc on its own?
thanks in advance
1 REPLY 1
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: Whole Home Disc Sets using as additional discs
Hi @scousemanblue
Yes you can do this, you'd need to install one pack first, then add the discs from the 2nd pack using "Add Another Disc" one at a time via the app.
Thanks,
Dan-O
