Newbie
Message 1 of 1
Whole Home Discs - Change SSID - App/Web GUI failing
Hi,
Trying to fix a bug on my two discs. Had them for a year or so and when I set this up all was OK. Recently many pages on the app and web gui are now missing.
I have master reset and plugged in one disc, all ok, I can view all the options on the app and web. As soon as I change my SSID everything goes wrong. The only options that are visible are WiFi settings under setup and disc status. Nothing else works. On the App I get HOM-016 errors. Tried all the web browsers. Reset the disc twice now and it is definitely fails after changing the SSID.
