fredu
Message 1 of 3
Whole Home: How to view slave details in topology view?
Hi
In the app ( I have a two node setup, one seems to have inherited a master and one a slave configuration), how on earth do I view the slave connected devices?
Everytime I click on the slave (Hallway - in Topology View), that in my case has 8 devices connected, the app always reports on the original master stats (lounge - which has two connected, and a completely different name to the slate...
Odd
2 REPLIES 2
BT Devices Expert
BT Devices Expert
Message 2 of 3
Re: Whole Home: How to view slave details in topology view?
Odd indeed. What happens if you swipe left or right on the picture of the disc? Do you see the other disc then?
Community ModeratorBrunoN
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
fredu
Message 3 of 3
Nope. Swiping left or right not allowed. For the life of me I just can't seem to even rename the slave to anything (it's currently got no name). Every time I try it defaults to the master
It's as if it doesn't even exist, although in the topology view it clearly does
