Message 1 of 2
Whole Home Hubs - Why so many design faults?
1) Why, when the placement of the Home Hubs is so critical do they supply a paltry 1.5m power cable.
Unless you want the thing on the floor, by the time you've reached a shelf or cill you have  about 50cm leeway on where to put it.
2) Why does it not have a wall hanging facility, the "stand" such as it is, as it can hardly keep the thing upright against the weight of a Cat 5 cable, is not removable so you have no choice.
3) Why do the hubs choose the farthest hubs to connect with when ones with excellent signal are nearer. Manual would be better than whatever automatic pairing algorithm they use.
1 REPLY 1
Message 2 of 2
Re: Whole Home Hubs - Why so many design faults?
Good question i've thought that too !
