jaymorley
Message 1 of 3
Whole Home Wi-Fi - Can The Disc Be Wired?
Decided to go down the whole home wifi route and have received my equipment this morning. Where the disc would be located, I have an ethernet socket which directly connects to the hub. Am I able to have the disc continuously wired rather than a wireless setup?
BT Devices Expert
BT Devices Expert
Message 2 of 3
Re: Whole Home Wi-Fi - Can The Disc Be Wired?
Hi, yes you can do that. Have a look in the user guide and on the app. If you have further questions, have a look on the Devices part of this forum where whole home wi-fi questions tend to be.
Enjoy your whole home.
BT Device ExpertBruno
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
jaymorley
Message 3 of 3
That's brilliant. I wasn't aware it had an ethernet connection on the back of the disc. Thanks, about to set it up now.
