Markba
Message 1 of 10
Whole Home Wi-Fi - Unpaused Device Unable to Access Internet
3 discs Premium Whole Home WiFi (firmware SGAB20226)
I had a schedule in place on a group to restrict access after 8PM, however there was a need to allow access as a one off. I removed the device from the group, however over the past hour I have seen either the message “internet is paused on this device” or there is just no internet access.
All other devices work fine and I have rebooted all discs and the device in question. I have removed the device completely and also tried to pause and unpause the device again but no luck.
I really don’t want to factory reset every disc and then have to reconnect every device again. Any other suggestions?
9 REPLIES 9
lnajr02
Recognised Expert
Message 2 of 10
Re: Whole Home Wi-Fi - Unpaused Device Unable to Access Internet
I would try to just power reset the discs, first , but if you should have to factory reset and re install then the devices should still connect assuming your WiFi SSID has not been changed.
Darren_B
BT Devices Expert
BT Devices Expert
Message 3 of 10
Hi Markba,
Could you try the following:
- Disconnect the device from the Wi-Fi, to make the device go into the "Offline list".
- Once the device is in the "Offline list", can you use the "Forget device" option (under the device details screen). Make sure the device has been removed.
- Reconnect the device to the Wi-Fi
This should hopefully have removed any stored schedules from the device.
We'll look into why you had the initial issue in the first place, so thanks for the feedback.
Let me know if the above does help.
Darren_B
Markba
Message 4 of 10
Hi Darren,
I had already tried your suggestion, but I am on the verge of giving up on the product. For this device I have had to point it back to the super hub as the old 8pm policy just keeps kicking in, despite it not existing.
I can also repeatedly able to knock the Wi-Fi off by running a speed test from the end of the garden. Within a few seconds of running it, the disc connected to the super hub turns red. Thus forcing a reboot of the disc.
MJ6
Message 5 of 10
Was there an answer to the pausing? I bought the Quad pack and they’re mouthing but trouble IMO. I have a device that pauses at 10pm, it in any groups, no schedules, been blocked and deleted to no change
Markba
Message 6 of 10
Afraid not. Unfortunately I have decided to send the product back due to numerous issues.
DeekB
Message 7 of 10
I am also seeing the same behaviour on the premium whoel home system, My little girl is off on School Holiday for a few days, I disabled the rules but unticking them but the devices  in her group still seems to be blocked, tried rebooting the wholehome system via the phone app, also tried rebooting the devices but they still dont come online.
I have took the premium system offline and moved back to the original gen 1 system, so far on the gen1 system it seems I have more stability again.
MurrayB
BT Devices Expert
BT Devices Expert
Message 8 of 10
Hi DeekB,
Have you tried the solution offered by DarrenB in an earlier reply in this thread? (I appreciate you have said you currently do not have your Premium system set up, but when you do you could try the following):-
- Disconnect the device from the WHW wifi which should move it to the list of Offline Devices
- Once the device is in the Offline Devices list, use the "Forget Device" option (under the Device Details screen) and make sure the device has been removed
- Reconnect the device to your WHW wifi system
This should hopefully remove any stored scheduling information for that device.
DeekB
Message 9 of 10
Hi Murray,
This was not my only problem, I have put the system back in the box due to reliability issues and reverted back to the orignal WholeHome Wifi System.
I have creeated my own thread here:
https://community.bt.com/t5/BT-Devices/BT-Whole-home-premuim-WiFi-system/td-p/2047638
MJ6
Message 10 of 10
This doesn't work. I then had an additional device that started doing it. I've had to do a full reset, and I'm yet to spend hours identifying devices and creating groups. The next time it will be returned as unfit for purpose.
