Message 1 of 3
Whole Home Wi-Fi app confused?
I've been using the Whole Home app on an android phone. When it stopped working temporarily after the firmware upgrade on the disks I also installed it on an iPad.
Now the android app is available again I'm getting different messages about the disks depending which app I use.
The phone app is saying:
Your disk is working well. You could try moving it further from your hub/router to get better range.
The iPad app is saying:
Your disk is working well, but you could try moving it closer to your hub/router to get better signal.
This is same for both additional disks. Any ideas which app I should believe or why they're giving different information?
2 REPLIES 2
Message 2 of 3
Re: Whole Home Wi-Fi app confused?
Message 3 of 3
Thanks, will do. I didn't know that one existed.
