My disks recently updated to v1.02.04 build10. Now the Ethernet port on the back of the disks is having some sort of issue.
The Ethernet port to my HH6 seems to be OK, but the Philips Hue Hub (PHH) connected to one of the other disks can no longer get a stable connection. The link itself seems to stay up, but the PHH comes and goes from the network. The BT HHWF App lists the PHH as offline and with a MAC Address of 20:D0:D0:D0:D0:D0. When it briefly connects the MAC address changes to the correct one before disappearing again.
The same issue occurs if I plug the PHH into another disk, but it works fine when plugged into my HH6, so this points to the change in HHWF firmware.
Anyone else seen this issue yet? Any ideas?
I’m having exactly the same issue, however didn’t realise until today that it’s the hub firmware update that’d caused it. I’ve reset just about every other smart device in my house after they started not operating as they should. Waiting to see if BT support have a downgrade option or if they’re just going to push out another fixed update (that’ll hopefully work)
Hi both,
Please could you share your System Log files with our helpdesk at btconnectedhome@bt.com to help us investigate this issue.
1. Go to http://mybtdevice.home from a PC/tablet connected to your Whole Home Wi-Fi
2. Log in with the admin password, then go to System > System Log and click Refresh, then Export All.
Share the log file + details of your set-up (e.g. Devices connected to the Hue Hub, which router you are using etc).
Thanks,
Dan-O
Just to note I have a Phillips Hue Hub plugged into the ethernet port of one of the discs and mine appears fine
Just an update since the Upgrade, all seems fine, I have noticed all discs went red then sorted themselves, this could of been an Internet drop out due to the weather, I have noticed once when the lights started to flash blue, but this settled and everything connected as it should, in the past this disc would of gone Yellow (Poor connection) but at least it came back blue
@Dan-O is there a way to attach the log
@Dan-O discs went through a reboot red light then the 2 discs that used to go from Excellent 5Ghz connection to Yellow Poor 2.4Ghz Connection on previous firmware has happened again on latest version
However while writing this the poor discs started to flash and have now reconnected themselves back to Blue Good and Excellent connections
Dan please can you review the log of one of the discs, below, is this normal functionality ?
@Dan-O another time within 20 mins that the discs seemed to have rebooted on there own, please comment on the log below
02.03.2018 17:38:26 [2 4 2] OWL-Adjust LED from Dim to Dim.
02.03.2018 17:38:26 [2 4 2] OWL-Backhaul WiFi Link Up apcli0.
02.03.2018 17:38:28 [2 4 2] OWL-Backhaul RE 2.4G exceeded the threshold for other reasons..
02.03.2018 17:38:29 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73811)dur(3600)
02.03.2018 17:38:29 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73811) dur:(3600)
02.03.2018 17:38:31 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73813)dur(3600)
02.03.2018 17:38:31 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73813) dur:(3600)
02.03.2018 17:38:34 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73816)dur(3600)
02.03.2018 17:38:34 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73816) dur:(3600)
02.03.2018 17:38:36 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73818)dur(3600)
02.03.2018 17:38:36 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73818) dur:(3600)
02.03.2018 17:38:39 [0 5 0] ATDP - Device's uplink path change from 2.4G to 5G [48:8D:36:EB:39:CB]
02.03.2018 17:38:39 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73821)dur(3600)
02.03.2018 17:38:39 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73821) dur:(3600)
02.03.2018 17:38:41 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73822)dur(3600)
02.03.2018 17:38:41 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73822) dur:(3600)
02.03.2018 17:38:42 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73824)dur(3600)
02.03.2018 17:38:42 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73824) dur:(3600)
02.03.2018 17:38:44 [2 4 4] DHCPC-Obtain new IP 192.168.1.148 and netmask 255.255.255.0
02.03.2018 17:38:44 [2 4 1] HTTP-start ...
02.03.2018 17:38:44 [2 4 1] Current firmware version is v1.02.04 build10 and boot flag is 1.
02.03.2018 17:38:45 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73827)dur(3600)
02.03.2018 17:38:45 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73827) dur:(3600)
02.03.2018 17:38:46 [2 4 6] NTP-Time Server successfully connected and time synchronisation achieved.
02.03.2018 17:38:46 [2 4 2] OWL-Backhaul RE 5G RSSI_LINKRATE(-72 1733), 2.4G RSSI_LINKRATE(-44 288) exceeded the threshold for 5G RSSI better than -75dbm.
02.03.2018 17:38:47 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73829)dur(3600)
02.03.2018 17:38:47 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73829) dur:(3600)
02.03.2018 17:38:49 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73831)dur(3600)
02.03.2018 17:38:49 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73831) dur:(3600)
02.03.2018 17:38:51 [2 4 2] OWL-Sync config success
02.03.2018 17:38:51 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73833)dur(3600)
02.03.2018 17:38:51 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73833) dur:(3600)
02.03.2018 17:38:59 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73841)dur(3600)
02.03.2018 17:38:59 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73841) dur:(3600)
02.03.2018 17:39:01 [2 4 2] OWL-IF[5G]:STA(E8:B2:AC:0C:2F:58)Added into unfriendly station list(AP_ROAM)rec(73843)dur(3600)
02.03.2018 17:39:01 [2 5 2] OWL-STA(E8:B2:AC:0C:2F:58) List all unfriendly station (AP_ROAM) rec:(73843) dur:(3600)
Wow, that is a pretty extreme way of getting around the issue, but the fact that you are back up and working again with a system with older firmware, points the finger at the v1.02.04 build10 being the issue.
