BristolPete
Newbie
Message 1 of 5
Whole Home WiFi GUEST Network
Need to know, is the guest network restricted to the 5Ghz signal. having problems connecting to it with 2.4Ghz devices.
Also if it is, are there any plans to enab;e 2.4Ghz on the guest network?
Running 3 disk system on v1.02.04 build 10
Each disk connected to cable WiFi for back channel.
4 REPLIES 4
tribunepind
Message 2 of 5
Re: Whole Home WiFi GUEST Network
I am sure it works on 2.4Ghz as my sons old Kindle is connected to our guest network.
BristolPete
Newbie
Message 3 of 5
Then I have a problem... my kindle won't connect to it, nor will my 2.4Ghz WiFi sockets 😞
Steve59
Message 4 of 5
@BristolPete Have you tried turning compatability mode on ?
BristolPete
Newbie
Message 5 of 5
I was just looking at that, trying to find out what it is...
 With Compatibility mode enabled, my kindle connects on 2.4Ghz... Don't know what Compatability mode is yet, but it does seem to be a solution.
