brummygit
Message 1 of 4
Whole Home WiFi firmware update check always fails
My whole home wifi has been working fine but I've read there is an improved firmware now available.
Every time I try using the iOS App I get an error asking me to try again in a few minutes, and the web interface simply sits with the spinning icon.
I've restarted everything without success. Is there a know work around for this problem or a way to manually download the latest firmware?
3 REPLIES 3
DarrenB
Message 2 of 4
Re: Whole Home WiFi firmware update check always fails
Are you using a static IP address?
brummygit
Message 3 of 4
I use DHCP reservations for each disc
brummygit
Message 4 of 4
Having tried rebooting the Whole Home WiFi discs via software previously, I did a full power down this morning. This seems to have worked and I've now sucessfully upgraded.
