Steve59
Message 21 of 1,165
Re: Whole Home WiFi firmware update v1.02.04 build10
Looks like a big anticlimax, TBH not many people are posting saying that they managed to update !
Steve59
Message 22 of 1,165
@Dan-O
Whats happening ??
Steve59
Message 23 of 1,165
Still no IOS App update either
BT Devices Expert
BT Devices Expert
Message 24 of 1,165
@Steve59
As I mentioned, the upgrade has now been staggered. All devices should be able to receive the update within the next day.
Do you have automatic updates switched on? I suggest turning it on, then you don't need to manually check for updates over that time.
Thanks,
Dan-O
Device expertDanO
Show your appreciation!
Kudos”Kudos”
abattle
Message 25 of 1,165
I have automatic updates on and it installed just before lunch. Everything running fine.
As a home we have PCs, Macs, iPads, iPhones etc etc and we’ve never had any of the issues others have described. I haven’t had the ‘not connected to network’ app error either. My WHW is connected to a smart hub so I don’t know if that has anything to do with it.
Rossboo
Message 26 of 1,165
I have had no luck either in receiving the update.
trapdoor
Expert
Message 27 of 1,165
@Dan-O wrote:
235175
Um, the auto update is only checking over a 2 hour period. What’s to say the time it checks it will get the update? So if it doesn’t, what then, wait until the next day, and the next ......?
@Dan-O are you really saying BT don’t have sufficient ‘capacity’ to handle more then a couple of simultaneous requests for the firmware? Why not just post up the firmware and allow a manual update?
jaybeetoo
Message 28 of 1,165
Having had the update for over 9 hours, it has been stable. I even managed a video call which before would have failed.
No sign of the iOS app update.
Hang on in there guys.
Dbaplaya
Message 29 of 1,165
got to the update, now get this:
Connect server error. FW upgrade stop. Please try again.
Steve59
Message 30 of 1,165
Update available from 11pm for me, all loaded ok from the IOS App
@Dan-O can you confirm the following steering settings as some were re enabled following the update, see the image below for the settings i have set.
