Steve59
Message 31 of 1,166
Re: Whole Home WiFi firmware update v1.02.04 build10
Dbaplaya, try rebooting discs if you can see the update as available
Dan-O
BT Devices Expert
BT Devices Expert
Message 32 of 1,166
@Steve59 Looks good! Let me know how you get on with the new firmware.
Dan-O
Dbaplaya
Message 33 of 1,166
have tried power cycling and still wont upgrade.
jaybeetoo
Message 34 of 1,166
A new version of the iOS app is available
ICAltd
Message 35 of 1,166
got the new build overnight automatically and the new andriod app this morning.
So far so good - and just completed an internet  speed check and I'm getting 135mb/s over wifi and I'm on the 3rd link of a chain on the mesh (have 4 disc's overall) so happy with that - BTWH connected to a virgin hub.
spiderlane
Message 36 of 1,166
Update didn't happen overnight. Several presses of the button finally promted it to show me the update this morning. Tried to update - then just goes from "Update available" to "No response from your network". Hard reboot of all discs and now the update is done - what a palaver!
Have re-enabled steering and will test. Fingers crossed; this update is the last chance saloon for WH - if it's not stable now with my laptop and Nest cameras I'm going to have to look for another solution (possibly going back to the heath-robinson lash up of powerline adapaters and cheap APs which was totally stable for years)
Cheers,
Mark
Dbaplaya
Message 37 of 1,166
So far so good. New android app and firmware.
Meerkatdawg
Message 38 of 1,166
Well...It's been a tough while living with no access to the discs after being so brilliant, but they still basically worked and I expected a new firmware update...didn't think it'd take nearly as long as this however. Bit disappointed in the slowness to respond by BT in general, but the discs/app/web access are back to working now and I still feel the WHWiFi is a really great bit of kit.
*Switches off automatic updates*
*Double checks they are off*
jimbg
Message 39 of 1,166
My discs and ios app have updated OK.
Where are the options for band steering etc located, I cannot find them?
jaybeetoo
Message 40 of 1,166
