jimbg
Message 91 of 1,165
Re: Whole Home WiFi firmware update v1.02.04 build10
@Steve59,
Yes, I did but that did not work last time I tried. Would like to get the app working as that is easier to use. than a browser on the phone.
Tony_Mac
Message 92 of 1,165
The mybtdevice web interface works - apart from getting one of our device names wrong
The App fails when trying to run on iPad
acamsell
Message 93 of 1,165
Since this latest updated applied itself on 28/02/2018 I've had to reboot by entire network five times a day.  Previously it had been stable for months.  I understand that there are sometimes unforseen bugs in new firmware but there really should be a rollback feature on the Whole Home discs so that if you have a stable system and it gets messed up by an update, you can at lease fall back to the last working state.
Right now I have a £300 wifi system that has been rendered utterly useless by a firmware update and I'm better off using the "free in every packet of corn flakes" router I got with the broadband.
antonypg
Message 94 of 1,165
Since the latest update my discs have been randomly restarting a few times a day, and occasionally I have restarted them when I notice that nothing is connecting to one or more. I really feel like I need to downgrade the firmware to an earlier version.
Alexwaddell
Message 95 of 1,165
Same for me, getting really frustrated with the lack of stability in this latest firmware.
Glasgow,
Scotland
MrX911
Message 96 of 1,165
Just happened to me again and BT don’t even seem to be acknowledging the issue or allowing people to roll back to a stable firmware.
simonjedrake
Message 97 of 1,165
Really strange.
After almost 2 months of a perfect working system with 5 disc showing zero dropouts, within a day of upgrading to the latest firmware I have already had two dropouts. From the app I was able to see that several of the discs were in Red status, so I turned them all off and after a few minutes turned restarted the main one on then the others once that 1st one was up & stable.
So far after 1 day from the 2nd dropout they have been working all ok ........... but I am waiting for the next unexplained dropout.
Steve59
Message 98 of 1,165
@Dan-O Looking at my logs my discs seem to reboot twice a day at least but come back on with good blue connections
I guess this is not normal
Steve59
Message 99 of 1,165
@Dan-O Sorry to report but my Macbook is not connecting when sat in another area of the house, disabled all Steering again and all seems well.
Will monitor the situation
abattle
Message 100 of 1,165
I hope it won't be another 2-3 month wait for the next update.
