I would assume it will be a staggered release so not everyone will see the update at the same time, otherwise the servers will get very slow...
Hi guys,
Just popping on to let you know I have moved the comments about the new firmware update to it's own thread.
Can I ask that if you'd like to comment please post on the new thread that's been created.
**Edited** - The link to the other thread is: https://community.bt.com/t5/BT-Devices/Wholehome-firmware-v1-02-05-build-01/td-p/1856831
Thank you!
Robbie
hello I have 5 discs and im losing connection it keeps on dropping sometimes it comes back on and sometimes we have to switch it all off to reset it.I have error MR204 & error MR104 on a blue screen.
@joann167wrote:hello I have 5 discs and im losing connection it keeps on dropping sometimes it comes back on and sometimes we have to switch it all off to reset it.I have error MR204 & error MR104 on a blue screen.
Change your 5ghz channel setting for your WH to 48 so it doesnt clash with Sky Q 5ghz ch36
I Stll have not updated firmware since i installed the discs and have left auto update disabled.
I still cannot connect to the discs using the App but they are all working it seems although i can only check via my PC.
This is frustrating, however i assume its because i do not have he latest firmware that my App on my iphone will not connect?
Anyone else have this issue?
Johnnyboy
