lnajr02
Recognised Expert
Message 1161 of 1,166
Re: Whole Home WiFi firmware update v1.02.04 build10
Hi I am using the latest firmware with no issues. What Device and version of OS are you using and have you talked to the BT Whole Home helpdesk yet.
jimbg
Message 1162 of 1,166
Yes I have the same problem.
I have 2 systems, the first is on the latest firmware and works fine through the app on my iphone.
The second system in a different location has not had the firmware updated and I can no longer access thought the iphone app.
Johnnyboy1964
Message 1163 of 1,166
Obviously it’s because I have not updated the firmware in the discs yet.
I’m reluctant to do this as they are working fine and I have good quality WiFi throughout my house.
But cannot use the App features.
Think I will leave as is for the time being until issues sorted with the latest firmware.
mikew88
Message 1164 of 1,166
To be honest, new firmware been used now for quite some time by many users and it seems pretty stable. I’d upgrade if I were you..
adrian_se
Message 1165 of 1,166
Firmware build v1.02.06 build11 is out
Tags (1)
largeinvestments
Message 1166 of 1,166
BT seem for a long time to have taken the view that they can use your subscription to create a wireless soup across the whole country using every hub distributed to help people as they drive by your house in their car, as if you would want to pay for them too. You used to have to actively opt out of BT wifi-with-FON and Wifi-X otherwise it keeps going. My dishes are great but I use a much cheaper providers hub and switch off their internal Wifi. Good luck with BT.
