Message 21 of 1,165
Re: Whole Home WiFi firmware update v1.02.04 build10
Looks like a big anticlimax, TBH not many people are posting saying that they managed to update !
Message 22 of 1,165
@Dan-O
Whats happening ??
Message 23 of 1,165
Still no IOS App update either
BT Devices Expert
BT Devices Expert
Message 24 of 1,165
@Steve59
As I mentioned, the upgrade has now been staggered. All devices should be able to receive the update within the next day.
Do you have automatic updates switched on? I suggest turning it on, then you don't need to manually check for updates over that time.
Thanks,
Dan-O
Message 25 of 1,165
I have automatic updates on and it installed just before lunch. Everything running fine.
As a home we have PCs, Macs, iPads, iPhones etc etc and we’ve never had any of the issues others have described. I haven’t had the ‘not connected to network’ app error either. My WHW is connected to a smart hub so I don’t know if that has anything to do with it.
Message 26 of 1,165
I have had no luck either in receiving the update.
Expert
Message 27 of 1,165
@Dan-O wrote:
235175
Um, the auto update is only checking over a 2 hour period. What’s to say the time it checks it will get the update? So if it doesn’t, what then, wait until the next day, and the next ......?
@Dan-O are you really saying BT don’t have sufficient ‘capacity’ to handle more then a couple of simultaneous requests for the firmware? Why not just post up the firmware and allow a manual update?
Message 28 of 1,165
Having had the update for over 9 hours, it has been stable. I even managed a video call which before would have failed.
No sign of the iOS app update.
Hang on in there guys.
Message 29 of 1,165
got to the update, now get this:
Connect server error. FW upgrade stop. Please try again.
Message 30 of 1,165
Update available from 11pm for me, all loaded ok from the IOS App
@Dan-O can you confirm the following steering settings as some were re enabled following the update, see the image below for the settings i have set.
