Message 291 of 1,165
Re: Whole Home WiFi firmware update v1.02.04 build10
I have been testing running just the master disc connected to the router with the two satellite discs turned off (till the new firmware is released).
This setup has been running and rock solid for ~ 48 hours so far. Obviuosly the WIFI signal and range is much lower than before but at least my Chromecast (and other) devices don't keep disconnecting.
I echo the comments of other contributors that BT should re-release the older ‘stable’ firmware and mobile apps (labelling them as newer versions) till the ‘real’ new versions are available.
I don’t understand why it is taking BT so long to provide an acceptable workaround for its user base.
Message 292 of 1,165
The BT CEO's email is **bleep**
Message 293 of 1,165
It looks like the forum software won't let me post that.
Scroll down to the bottom of this page.
**Edited**
Message 294 of 1,165
Message 295 of 1,165
No they should not release the old firmware as New as for me the newer firmware is a better, not perfect but better
I suggest if you need the old firmware then it needs to be released as in option
Message 296 of 1,165
And TheRegister: http://www.theregister.co.uk/2018/03/26/bt_whole_home_wi_fi_issues/
apparently BT are "aware that a small number of customers have been having problems" - what tosh!
1) We need fixed firmware, including the ability to manually install previous firmware versions
2) BT need to properly test firmware before releasing it into the wild
Message 297 of 1,165
Checking my system on the weblink and it showes one disc at 2.4 POOR CONNECTION
YET Connected to that disk is another a 5.0 Good connection?
How does it do that !!!!!
How can a disk showing 2.4 Poor connection feed another at 5.0 with a good connection?
Message 298 of 1,165
I am guessing that the poor disc is too far from its connection but then it generates a good onward signal at 5GHz which is closer to that other disc if that makes sense
Message 299 of 1,165
I agree, the firmware probably isn't smart enough to take into account anything more than the first link in the chain.
Expert
Message 300 of 1,165
I think you may find it bounces back...  reports elsewhere are that e-mails have been returned un-delivered.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
