abattle
Message 81 of 1,165
Re: Whole Home WiFi firmware update v1.02.04 build10
One of my discs is now solid purple! Tried resetting the system, two reset and this one stayed purple. It doesn’t reset when I stick the pin in the reset hole. Any suggestions?
antonypg
Message 82 of 1,165
Glad to see the web interface is fixed, and the app works a bit better.
However, my discs are restarting themselves for no real reason. All of mine are connected via Ethernet, one disc has been running for 23 hours but my two other discs just restarted ten minutes ago (at exactly the same time!!!).
This happened yesterday afternoon as well. Mine are set for automatic updates at 3 in the morning, not sure why 2 of them would crash at exactly the same time at 5 in the afternoon?
Neils83
Message 83 of 1,165
Hi,
i have updated to the latest firmware, every worked fine in previous 1.02.03, however now it is not allowing Ethernet bridging on either of the other 2 discs. Is there a way to force downgrade to previous version? My zig bee kit is connected to one of them and therefore essential I get it working. Cheers
MrX911
Message 84 of 1,165
Avoid this frmware!
Is there anyway to downgrade? I suspect not 😞
Tony_Mac
Message 85 of 1,165
Updated disc firmware and wifi is working OK - Thank you for the support Dan-0
Bug - The web based interface is getting the connected Device names wrong?
Bug - Cannot run the app on iPad - the app cannot connect to wifi and just HANGS 😞
Deleted then reinstalled app, but still not working 😞
Any ideas?
Thanks again,
Tony
BT Devices Expert
BT Devices Expert
Message 86 of 1,165
@Tony_Mac
You need to switch off all your discs with the power button/at the plug for 1 minute, then turn them back on.
Dan-O
Device expertDanO
Show your appreciation!
Kudos”Kudos”
orientboy2000
Message 87 of 1,165
Dan-O
when you turn them back on I assume the connected disc is first let that boot up. Then can you just switch the others all together or do they need to be one at a time untill each has fully booted?
jimbg
Message 88 of 1,165
I have updated my ios  app and the firmware on my home system and all is OK.
However I want to update my neighbours house and the app still will not allow you to connect to a different network.
I have uninstalled the app to try and get it to forget my network, but I reinstall it remembers my network.
His phone is an old Android one and not supported by the app, for the install I was able to borrow his son's phone to use.
Unfortunately he is not visiting for a while. Is there any way of resetting the app?
Steve59
Message 89 of 1,165
@jimbg, Have you tried the web interface http://mybtdevice.home/login.htm
Tony_Mac
Message 90 of 1,165
Dan-0,
Turned the 3 discs off at plug, left for 10 mins - the App still fails to find the wifi network 😞
Any other ideas?
Thanks,
Tony
