worrum
Message 1 of 2
Whole Home WiFi log in
Hi,
Please forgive me if this has been asked already..I am not good with reading and retaining.
My wife has just brought me whole home wifi. I am ok with downloading the app and setting it up. My qiestion is this.
Once set up do all the devices in the house have to log onto the whole home network via the disc log in... or do they still remain logged into my home hub and receive the sigmal from the disc.
So for exampe, the sky box in my bedroom. Do I leave it how it is or do I have to re log in using the disc network name and passcode.
Thanks in advance and kind regards
Rob.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Whole Home WiFi log in
Hi @worrum,
Once you have set up your Whole Home Wifi, you'll need to connect your devices to the new network. You'll find the SSID and Wifi password on the back of your Whole Home disk.
You can find out more by looking at - Whole Home Wi-Fi
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
