rwroddie
Message 1 of 3
Whole Home WiFi
I have an existing 3 disc system which works fairly well. Can I add a 2 disc pack to this system and if so how .
2 REPLIES 2
albertj
Recognised Expert
Message 2 of 3
Re: Whole Home WiFi
Hi @rwroddie
Welcome to the Community!
Thanks for posting.
Yes, the whole home system can support up to 6 disks.
You can follow the instructions in the app, but you just need to plug the new disks into your router, with the other disks still on, wait for it to go blue, and then put it in its new location.
There's a video walking you through it here: https://youtu.be/5oekdrjheqo
Thanks,
AJ
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Darren_B
BT Devices Expert
BT Devices Expert
Message 3 of 3
Re: Whole Home WiFi
Hi rwroddie,
Yes you can add up to 6 discs on a BT Whole Home Wi-Fi system.
But please ensure you buy the same discs as your existing BT WHW system, as the newer 'Mini' is not compatible with the original larger white discs, and vice versa.
Many thanks
Darren_B
